Hi my engine is acting up again. It's been a couple of months since I fixed the engine running rich from not getting PCV air back in.Now the spark plugs are fine and not fouled. I even replaced them with DENSO and also put in a new fuel filter. It didn't help.
The engine would randomly miss a couple of strokes while criuse at 30-40 MPH. Or it would do that during light or heavy acceleration while on 2nd or 3rd. But not necessarily under heavy acceleration.I can always hear a pop from exhuast when I let go of the gas. I can also hear it when the engine misses.I'm running Plus in my gas tank right now. New air filter, plugs, fuel filter, no EGR.Should I advance the timing by rotating the distributor counter clockwise for a couple of degrees? Will it fix that?
Thanks
