andremike wrote:I think the y pipe is out if a muffler shop wont install it.
What is the advantage of going cat back vs axle back?
Why doesnt borla offer catback?
The stillen offers 2 exhausts and the borla 1.
The 2 exhausts is similar to the custom job you did with the magnaflow.. what parts from magnaflow didyou use? And that was cheaper then the catback from stillen? With all the custom work you probably needed.
Mine was $600 all done. I bought all the parts myself, then took them to the shop to fab. I took it to a local oil and lube and they installed the y-pipe for $50, so $650 for a full job from the headers back.
magnaflow tips: 35121
magnaflow muffler x2: 14235
custom 2.5" midpipe. (shop fabbed)
one 2.5"in-two 2.25" out ysplitter (shop fabbed) <-- both of these were included in the above cost
The stock midpipe is 2.25" if I'm not mistaken, so that is why stillen offers 2. Open its up to breathe some more, but with a naturally aspirated motor you don't really want to go up to 3" or you won't have enough back pressure.
The muffler shop said it was a breeze to work on. The mufflers I got had offsets for the in/out, so minimal bending was needed, and its one long pipe from the cat to the y splitter into the two mufflers. plus there's plenty of room under there.
The stillen cat-back has a resonator in the midpipe as well, I don't, but compensated by putting bigger cans for the muffler. Bigger can=quieter sound. At highway speeds or light acceleration, you can tell its not stock, but when you get on it, it sings. Plus with the stillen you still wont have the y-pipe, it will be additional. Find the right shop, and they might fab that for you as well. I'd recommend the racingline one though, it bolts directly in and comes with gaskets and everything.
Long story short, yes, my system was about $200 cheaper than stillen or Borla, and its the sound
I wanted, not what someone else thought was good or that everyone else on the road had. Highly recommend.
The y-pipe is listed at $290 right now, but I'm sure you can find a used one cheaper, maybe here on the forums, but that also makes a big difference in gains and sound.add in that price, and I'm at $940 for the setup, $140 more than the stillen cat back alone, and about $200 more than the Borla axle-back.
