Exhaust on. now i've got a BOV question
Doogz
Car: '89 240sx coupe
My Blitz Nur Spec came in and it is extremely sexy. Whoever said they were really loud doesn't know what loud is, mine sounds just fine. But now with the exhaust i can hear the BOV and its definately not working. I get the sputtery, air slamming into turbo noise. Anyone have any suggestions on what to check? I figure i'll make sure the vacuum line i tapped into is ok and i figured i'd try to move it manually to make sure it wasn't frozen. Is that about all i can do?
chezina
Is it an adjustable BOV? If so, try to adjust it (depending on what type of BOV your using u have to remove some washers or just unscrew the adjusting bolt), maybe its adjusted for a lot more boost and will not open at the boost your getting.
Doogz
It's a first gen DSM BOV and as far as i know the only thing they do to adjust those is to crush the top of it.
elballoonrat
Car: turbo mr2
i would take it out and hook it up to a air compressor, might have blown your blow off valve, o rthe top might just need some resealing with jb weld.
drumma022
hooking up an air compressor wuold definately not open the bov UNLESS you are running it backwards! :) or have a proper fitting to simulate vacuum.
If you need a new BOV, I have a skyline BOV i will be looking to sell in a bit. SEAN, you may want to jump on this deal if you dont already have one. It is worth $60 to me. This is a factory Nissan part, but made by diamond star motors. :)
NeedCAforS13
Car: CA swapped S13 coupe
i'll take it ray! :D i'll be calling you sometime soon...maybe give me a deal on everything? (head, pistons, bov, boost gauge ;)) let me know what you think...
Sean
