gbxk86a »
https://forums.nicoclub.com/gbxk86a-u6206.html
Tue Apr 01, 2003 11:44 am
My '96 I30 has about 98,000 miles. About 5000 miles ago, we can smell strong odor (very much like exhaust) everytime I made a stop or had a turn with slowdown with AC/heat on. Have asked the Infiniti mechanics to look at it three times. The mechanics kept on pointing at the slight damage at the trunk as the reason the exhaust leaked into the car. I used towel to stuff shut the two inlets in the trunk, but still had the odor problem. The only way is to activate the recirculation on the AC on to shut off air from outside. In the third time, the mechanics said likely it is the carburization of the fuel injectors created some combustion problem. He did have a lengthly explanation, but I could not catch everything he said except it had something related to fuel/air mixture. Had the injectors cleaned, and the problem seemed to be somewhat better, but the odor is still there although not as rich as before.Is his diagnosis correct? If the problem has improved, should I add fuel additive or had decarburization done one more time to get rid of the problem completely?Need some expert advice.
