Exhaust note
twofst4u
Car: 06 g35 sedan 6mt
I love the sound of the coupe dual exhaust note...is it possible to swap the exhaust with the coupe dual to my sedan & achieve the same note? Just wondering if anyone tried this yet and the labor involve. thanx!
infinititech1
it would take alot of modification...never seen it done... thats why if i had to choose between a sedan and coupe...i would get the coupe just cause of the exhaust noise
joe603
Car: 2014 Durango R/T
Really!? I thought this was a pretty common mod??
DOHCscreamer
i was just about to post the same question. does anyone make a dual exhaust for the sedan? does anyone make an exhaust that sounds like the coupe and is mellow like the coupe (single or dual exhaust)?
G_whizz
Car: 2010 G37 Coupe Sport
Try here for Sound clips
http://www.g35turbo.com/Exhaust-Sound-Clips.html
Hope that helps.
DOHCscreamer
G_whizz wrote:Try here for Sound clips
Hope that helps.
those are all for coupes and 350z's. the thread is about sedans.
G_whizz
Have you tried some clips on youtube? When I was looking for exhaust clips, I'm positive I saw some people on there with sedans doing sound checks.
C-Kwik
I think the biggest hurdle will be the fact that the sedans use a single exit area for the exhaust. The coupes use a dual putput exhaust with the muffler underneath the trunk. Not sure if there is enough clearance for the muffler section to even fit. And certainly with the longer overall length of the sedan, it would require some modification to the piping as well.
twofst4u
Im with you on that Dohc, it doesn't have to be be dual as long as I can get the same note.
Gdubya35
Car: Infiniti G35 Sedan
So, has anyone in this great forum found out anything about the exhaust surgery? Is it worth it?
Crashtest77
Car: 2003 G35 coupe
No, I have a coupe,but for the sedan the answer would be no. I'm sure infinitech can tell you, you'd probably have to move or cut a lot of crap to shoehorn that in. Best bet would be what gwhizz said to check out the soundclips on youtube or on the site he listed,and find the sedan model and find a soundclip for it.
thechronic
Car: 2003 Infiniti G35 Coupe
how does the borla dual exhaust compare to the esteemed stillen exhaust system?
