3.7 is not direct injectionM37xfan wrote:I believe the noise at start up deals with the direct injection. Once the reaches operating temperature it should go away. My M37x does the same thing. I have noticed that in warmer temperatures it is not as noticeable
When you did your own exhaust, are you talking aftermarket, or r&r the the stock pieces?Ilya wrote:I've actually noticed this on my 07, haven't noticed it on my 11 although I haven't specifically tried to hear it...will try next time I'm by the car. I also noticed this on my 99 Maxima. I always thought it was normal as a result cause the exhausts I had on those cars were done by me and done well (I go overboard on small details like gaskets, sealant, etc.). No way in hell I had a leak.
I actually always thought it was the EVAP system or something releasing pressure to be honest but never really looked into it.
On my Maxima and 07 M35x, it was after market/performance exhausts. Unless I'm confusing the sound on your video with what I heard...mikedamageinc wrote:3.7 is not direct injectionM37xfan wrote:I believe the noise at start up deals with the direct injection. Once the reaches operating temperature it should go away. My M37x does the same thing. I have noticed that in warmer temperatures it is not as noticeable
Wouldn't it trigger the SES light if it was the case?Frog wrote:To me it sounds like a manifold gasket and as it warms up seals the small hole ? What do u all think. I have the same sound on my g37
