Alibireason »
https://forums.nicoclub.com/alibireason-u299870.html
Fri Aug 05, 2022 12:16 pm
Two days ago I had my driver's side exhaust manifold replaced on my 1998 Pathfinder (CA emissions). Shop quoted me $625. Same shop had done minor work before and I liked how they did business. Upon arrival to pick up he shows me old manifold, It was broke in two, and he told me he had to charge full price because of just how hard it was to remove ($670 with tax). No problem, I appreciate the hard work. Fire it up and it sounds great, much quieter and stronger feeling. Its end of day, mechanic leaves as I'm warming up car. Next thing, in park, rpm jumps up to almost 2000 and starts whining, then drops back. Then I check and Engine Light is on. Plug in my scanner, it reads P0154. I clear it and drive home and code comes back (5 mile drive). Once home I open the hood, smells like burning rubber. I notice tube coming down from EGR is side by side touching the rubber tube coming from power steering reservoir. WTF! I think. Then I notice he didn't put the heat shield on. He just didn't do it (probably from the difficulty he mentioned earlier but who knows).
Next morning I check 02 sensor, its tight, and my common sense told me to move the power steering tube away from the EGR tube. I clear the CEL again and drive for about 30 miles. The RPMs didn't spike at all and the CEL hasn't come back.
I'm curious to get opinions from others about these thoughts:
No heat shield? it it necessary? or were they lazy?
HOT! EGR tube literally touching power steering tube (it did start melting)
Not informing me of CEL.
Do you thing my CEL will come back? Does this story sound like a "normal" exhaust manifold replacement?
