M30 Steve »
https://forums.nicoclub.com/m30-steve-u17176.html
Sun Mar 11, 2007 3:32 am
Hello Isch.
Sorry to bring bad news, there is a TSB on the exhaust manifold studs. They were recalled for lousy steel I guess. I went to change my manifold gasket a couple years back. I thought it would be a 2-3 hour job. Big trouble when every manifold stud broke off.
I was not able to remove the studs, tried a right angle drill with no luck. It is nearly impossible to drill the center of the stud without slipping off. The work area is very limited you will notice.
I ended up pulling the head and running it to a machine shop. The shop uses a process called EDM (i think) to extract the studs, they install an upgraded stud.
You can read further info at ALLDATA or f31club.com. Moral of the story my 3 hour job turned into abou a 12 hour deal and a trip to the head shop. Many VG30 owners have had this happen.
Thanks, Steve
