Justin35ll wrote:how can't you get it? I just removed my manifold the other day. all I used was a regular 3/8th ratchet, an extension, and a swivel for a couple of the nuts.
iirc that last nut your talking about was one of the easier ones to see?
edit.. waitare you trying to remove the turbo bolts with the manifold still on the car? Good luck i say just remove the manifold you're making it much harder for yourself
no, im trying to remove my exhaust manifold so i could replace the gasket and inlet gasket. i got everything off but this one./pu_s15turbodiagram.jpg?t=1256101046]
http://i44.photobucket.com/alb...01046[/url]
Modified by slideways21 at 10:07 PM 10/20/2009
