jcquick wrote:The gasket between the exhaust manifold and the turbo went out on my S13 SR20DET motor. I'm going to buy an aftermarket manifold since I have to take it off anyways. My question is, If I purchase an aftermarket manifold will the location of the turbo and exhaust match up properly. I plan to change the exhaust later on but I need my car up and running NOW. Which manifold do you guys recommend: Ebay, DC Sports, Megan etc. ?
The location of the turbo will be in the general vicinity of where it sits with the stock manifold. I've used a few of the aforementioned bottom mounts and never had an issue of alignment with the turbo outlet, oil return or length of the intake runner. Ebay specials and Megan are the same thing- Made in China, but they do the job. Don't wrap the SUS 304 piping, which is what these pieces are made with because they are brittle and will crack with retaind heat. If you do get an Ebay/Megan, take it to a welder and get the welds looked at and reinforced.
