compactfean wrote:Thanks alot man. I just wanted some info from someone that's been in my boat. I think my buddy would trade me for his stock Mani. Can the stock Mani flow good power externally gated? I like the idea of more umph down low but will it hurt any top end? I've never ran a upgraded Turbo on a stock Mani.
The stock manifold has proven to really be the best manifold for any t2 based turbo. Most tubular setups actually reduce spool up, and don't make any more HP up top...ultimatly we're all limited by the restrictive housing, so getting the gas their faster doens't help anything.
The OE manifold is actually a nice divided manifold (as it keeps 1-3 in the same side, and 2-4 in the other) to help create a better path to the turbo (not to mention it's divided all the way to the turbo gasket, sweetness).
If you really want a badass manifold, send it out to extude hone, and then to swain coat...you can't touch it!
In terms of power production, you'll see another 20ish troque from the stock manifold, faster boost onset, and good top end. I've had my setup copied a few times now all making 385-410 whp...not bad! Even the FWD cars (granted slightly different stock cast manifold) do well!
