dattodude »
https://forums.nicoclub.com/dattodude-u30125.html
Tue Oct 03, 2006 2:12 am
The exhaust leak may be sucking fresh air into the exhaust, causing the 02 sensor some confusion.
Just fix it :-)
The 'extra oxygen' may be telling the computer to add more fuel, causing exhaust backfiring, and I expect, bad fuel economy.
Disconnecting the o2 sensor would be my first test.. if things improve, then it's definitely letting air into the exhaust, and past the 02 sensor.
Disconnecting the sensor is a test..not a solution.
Your friends car just might have an engine with less coke around the valves, and/or better compression. Yes, the smaller turbo with higher boost will out accelerate your car. Turbos should be sized for an engine, bigger is rarely better. The GTiR T28 should be ok though generally speaking.
Hope this helps.
