exhaust leak help!
240sxs13sleeper
Car: space shuttle
hey guys.. been searching and no luck.. just ran into a problem. recently my car all of a sudden when i gunned it. it doesnt boost until 4000 rpm. when it usually starts boosting at 3 something. so one morning i went to turn on my car, popped open my hood and felt for any air leaking around the turbo and turbo parts. and i did.. but i dont know what the exact name gasket it is.. oh and if this helps. i got a aftermarket turbo manifold.
the exhaust leak is coming for where the manifold connects to the stock turbo. i checked to see if it was loose screws and that wasnt it. also i checked in the 'crossover parts between usdm and jdm ca18' and still couldnt figure out which gaskets which
thx alot
-thao
meminto
Car: S13 Silvia CA18DECT
As an example, this is the gasket type you will require if it is a T2x (ie T25 T28, GT series etc) based manifold you have...
http://images.google.com.au/im...a%3DN
Hope this helps...
boost_boy
240sxs13sleeper wrote:hey guys.. been searching and no luck.. just ran into a problem. recently my car all of a sudden when i gunned it. it doesnt boost until 4000 rpm. when it usually starts boosting at 3 something. so one morning i went to turn on my car, popped open my hood and felt for any air leaking around the turbo and turbo parts. and i did.. but i dont know what the exact name gasket it is.. oh and if this helps. i got a aftermarket turbo manifold.
thx alot
-thao
Gasket got smoked! You will need to take the manifold and turbo off and do the necessary repairs.
Dee
240sxs13sleeper
Car: space shuttle
hey thx guys
