eastcoastchaos »
https://forums.nicoclub.com/eastcoastchaos-u4408.html
Wed Jun 01, 2005 2:35 pm
car was running super strong for a couple days outside of my starting problem. then. my plugged egr hole in the header popped out and left me with a super loud nasty exhaust leak. i brought it home and used a 3-4 inch section of the egr tube that i crimped down to fix the leak. i tried to start it again and it wouldn't. i pumped the gas and tried again, it started but with a loud metal tapping sound and really really rough idle plus the whole car was shaking. after 20 seconds or so on the gas it made some funny noises then started to idle perfectly. i drove it to work just fine with a tiny bit of car shaking. on the way home it was back to being super rough and i had to heal toe crazy drive just to keep it running in neutral but i got home and now i'm lost. o2 sensors good now, i knocked it out when re-plugging header, and theres a ground wire on the back of the motor that had some copper freying out a little, but i fixed that to no avail. same problem only i broke a spark plug wire when i was about to do a compression test. any advice? other then sell this piece sorry for so many posts but it seems like everything is broken
