Exhaust install question, HELP!!
movado750
Do the bolts on the stock exaust come loose? I'm putting on Megan Cat back and I can get the nuts off the bolts but cannot get the bolts out. Do you have to take the hangers off of the car and then put the hangers on the new exhaust and put the hangers back on?
Am I missing something? Do you have to loose anything else up to install the cat back sytem?
I was thinking this would be easy but it is not working out that way.
06M4.5
Car: 2006 M45
If your bolts are rusted you need to cut them off or you can also torch them off.
Sometimes it's better just to go to a muffler shop & get it done.
finikM35
Car: 2007 M35x tech package
5/16 plenum spacer, element 114 exhaust, ztube,k&n, grounding kit, uprev tuned, D2 coilovers.
Could try to heat em up and they might get loose. Mine were rusted and pita to remove I replaced all the bolts got some from autozone they were cheap.
cruzad3r
Car: 2006 Infiniti M35x fully loaded
ya either that or use an impact wrench to take it off.
