Are you absolutely positive it fits the SR-T?codyace wrote:Goto your Nissan dealer
Order an exhaust manifold gasket for a 2000/2001 Nissan Sentra SE-R with the 2.0 (sr20de)
It's multi layer metal, and should cost under 20 bucks
14036-7J500
It's the same exact part lol, not much of a deal.Thoughtful_One wrote:I called up my local Nissan dealer for prices and he said $22 plus tax.
Thought I was going to go for it until I found a better deal. $30 shipped for a brand new S15 gasket, so I jumped on it.
Remember that the majority of SR20DETs that were produced were RHD, meaning no Steering Shaft in the way.Hijacker wrote:I've successfully pulled out turbos and manifolds with the elbow still attached before. It's infinitely easier without the elbow attached. The elbow tends to get jammed in weird angles and the lip of the flange catches the steering column. However, pulling the elbow with everything still in the car irritates me as well. Nissan engineers should be shot for designing some of those bolts.
I guess I was directing the comment at the removing the assembly all at once.Hijacker wrote:The steering shaft and brake master aren't in my way when I start removing bolts for the elbow. The rest of the car is. The two bolts on the motor side of the elbow are just a pain to get to. It's because of the casting of the elbow.
