exhaust gasket--ka24e manifold gasket.
nissilvat
Car: 1990 240sx
i ordered an obx header from ebay. i just received it today but noticed i was missing a gasket. does anyone know where to get a godd manifoled gasket for my new header?, also some of the holes on my block for the exhaust manifold are stuck in the holes caused the heads were torn off. would it be wise to heli-coil all those holes then put in new s/s stud bolts to mount the new manifold on?
9240sx
Car: What i believe to be the cleanest s13 in the world.
SR20DET + RS*R-Apexi-Nismo-Trust-HKS= 100% pure love
Napa sells good exhaust gaskets.
240sx2soon
Car: Soon to be 96 240SX SE
If your bolts broke off you should do your best to get them out, regular studs will work fine if you use anti-seize before installing them. Any time you put steel into aluminum or for any high heat application you should use anti-seize.
nissilvat
Car: 1990 240sx
well what i was plannin to do was use one of those ( taps ) or whatever and drill it out, then install the heli-coil kit and put in studs to mount the header on. you think i should use s/s or grade 8 studs, which is stronger?
