philb »
https://forums.nicoclub.com/philb-u56216.html
Wed Apr 22, 2009 1:30 am
the fuel filter is in the gas tank, mounted on the same aparatus as the fuel pump and fuel level float.
You need to search this site for the link to the Factory Service Manual, and download it. It will answer most simple questions for you. I've learned a lot it.
I have no experience with the K&N.
I've heard both sides of removing the exhaust valve, but I kinda doubt it would help that much, because the engine's flow characteristics change according to the variable intake valves - I'm thinking that when it isn't opened it actually helps the torque curve in lower rpm operation, and doesn't need to open until higher rpm, higher flow operation.
The transmission ECU will learn how you drive it even if you don't disconnect the battery. After a few runs, (I don't know how many) it will learn that the new owner's right foot is heavier than the previous one's.
One other thing you need to do is to check to see if the previous owner changed the transmission fluid. I think the factory recommends every 30K, which they recommend to help them with their warranty coverage...so you should change it too. I had a 92 Q45 that ate transmissions, but I must admit I ran the **** out of it.
Don't see many '03's, and even fewer red ones. I think that's a good color.
Good luck with your car, I love mine. 80,000 miles so far.
philb
