exhaust flamethrower (yes i tried search)
crna1
Car: 2003 infiniti G35 Coupe
heres what i want to dosplit into main fuel line and run that to small pump and from the pump to a NOS fogger inserted into the exhaust just after the muffler, where there will be a spark plug attached to a coil) = flames.without being judgemental about the plan itself...will i affect anything significant by running a line off fuel line like this. it will not be continuous flow..will be switched and only run at special events (ya know, impressing friends, chicks, etc)thanks
Defiant
Car: 1997 J30
No trouble other than blowing the back half of the car off. ¼-cup gasoline = 1 stick dynamite.Better to stick with someone who's already figured out how to do it "safely":http://autoloc.carshopinc.com/...FLAME
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
NICO finally has a candidate for the Darwin Award!
I know what Porsches are meant to mean for a man's masculinity index, but flames?
sijoko
Car: Black 1994 Infiniti Q45 Turbo, Pearl White 2014 Maxima Sport
If you really want flames, then get the kit.
Don't inject fuel into hot exhaust pipes unless you want to experience the other side.
infinititech1
buy kit
crna1
looked at those kits..problem is the way they work is to interrupt ignition..raw gas runs thru cylinder..thru catalyst..out to exhaust. never thought that was a good system, plus most (all) fuel burned off in catalyst)
i really just wondered if by diverting gas flow i would piss off some sensor or computer somewhere. since would not be running it while driving, dont care if it would affect performance
crna1
maxnix wrote:NICO finally has a candidate for the Darwin Award!
c'mon..i know its stupid (read the question again..i asked for non-judgemental replies) Stupid is fun..and your prob right about the darwin thing, but...
crna1
so ..is this the tech side? can i get a real tech answer as to if the car will notice me occasionally diverting gas?
i guess i should have prefaced the question..'i know this is stupid, but god i do like a good fire'
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
crna1 wrote:'i know this is stupid, but god i do like a good fire'
Me too, but not in my car outside of the combustion chamber.
Maybe start by lighting your farts first.
Be very wary of anyone who is attracted to you by this act!
SR20Essex
Car: 1989 Nissan 240SX, 2007 Infiniti G35 Coupe
You could use the flame to cook some RICE!!!
Defiant
Car: 1997 J30
crna1 wrote:looked at those kits..problem is the way they work is to interrupt ignition..raw gas runs thru cylinder..thru catalyst..out to exhaust. never thought that was a good system, plus most (all) fuel burned off in catalyst)
And bear in mind just what a tiny bit of gasoline that'll be. That's to belch out fifteen or twenty feet of flame.Quote »i really just wondered if by diverting gas flow i would piss off some sensor or computer somewhere. since would not be running it while driving, dont care if it would affect performance[/quote]Not that I can think of, but the problem is that you want a dozen drops or so, nothing enough as to call it "diverted". Because of the depth and breadth of dangers involved, I'm not divulging "good" plans for a DIY flametail, but I'm sure they're already out there on the internaweb.
