float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Thu May 13, 2004 3:51 pm
You don't have an exhaust leak before the turbo anywhere do you? Are you sure that the flapper door on the wastegate isn't cracked/broken? A turbo is a pretty simple device. If you want to make sure it's moving air, turn off the car, unplug the MAFS, remove the hot pipe and start it. Rev the motor and if you feel a good amount of air coming out of the turbo, then it's working and you have to have a boost leak somewhere. When you say it's not boosting up, do you mean that it's not making boost at all, or not reaching full boost?
