Exhaust backfire AND sudden surge of power after 5000rpm??? read on first!
OK. Well I have put some thought into this, and have read a number of posts here with people who share similar exhaust "problems" as I do.
For those of you who suffer from mild exhaust pipe combustion noise upon certain RPMs while decelerating, please continue reading.
My thoughts on the KA is that its a great engine and is pretty much rock solid for reliability. The thing however that seems to go on almost every "high milage" KA is the coolant temp. sensor which I understand has a direct effect on ignition timing.
Crazy ignition timing = crazy combustion timing = putt putt putt
Anyways, I dont KNOW this but those who participate in the poll should draw a fairly reasonable indication of the conclusion.
For those of you interested in one of the many interesting reads check this out. It is nothing special in particular with exception to the increase of power issue.
http://northwestnissans.com/bo...18485
Thanks for your time.
-Mike MurphyPlease share your symptoms
