Conversion to OEM that is =/
There's been a couple hailstorms out here and we got a company to fix our roofing. Well the roofing company blocked one side of the drive way with a bunch of roofing material. It wasn't light enough to move so I had to work around it. But anyway, I usually pull in at an angle where the stuff is, reverse out at an angle, and then drive into my side of the garage with the help of the planks of wood you see on the ground. With the materials in the way I had a really hard time doing my usual routine and the wood ended up getting caught on my subframe, midpipe got stuck on wood / concrete ledge on edge of garage, reversing with half of my car on the wood / off the wood at an incline jammed my exhaust into the ground and voila! The first picture is the end result.
I figured the piping just came off the hanger and it'd be an easy fix. I was dead wrong. It was off the hanger but the tips would not realign with the holes no matter how I tried. I got it close, but not nearly close enough. Ended up running a muffler delete so that I could take it to a shop. The shop quoted me about $250 to fix it. One exhaust outlet was actually jammed up towards the end of the axle, meaning it was out of alignment. They would have to cut & re-weld the damaged part, and then try to line it up properly on my car via trial and error. I didn't want to put money into a free exhaust, especially since I'm broke so I decided to put my OEM one back on. I miss it so badly.. Car sounds super frail lol. Now that I don't have it and looking at buying a new one / fixing it, I really realized how nice this exhaust is. I wish I could have done a drive by recording before this happened. With this exhaust and an intake, it sounds like a stock / lightly modded g35 or 350z. It sounds PERFECT, not raspy at all. And like people said, it got deeper in time. I'll probably end up fixing this one or buying another one and adding new tips.
I know my car is low and stuff like this comes with the territory but this was merely an accident. I never have issues, I don't drive as slow as you think so don't get all crazy about how being slammed is stupid blah blah. This is the first time where being low has damaged my car.
