exhaust cam help
racemonkey11
I tried installing the exhaust cam mod and I tried it at 3 and 4 teeth and it will not run whatsoever am I missing something and is the first lobe supposed to be at the same angle as what the stock intake cam is supposed to be?
S13_RB25
Car: A 240 but no RB yet!
Its supposed to look exactly like the regular int cam does. So the first cam lobe facing outside, I think you rotate the exh cam 3 teeth counter clockwise, that's how did mine and cranks up just fine! Did you set the timing at TDC prior to messing with the cams?
racemonkey11
Ya I put it on tdc but I noticed that the intake lobe is facing a little higher than what the stock one would face is this how everyone else's looks like? Oh and just to add I used the orange colored cam from an s13
S13_RB25
Well try installing the stock intake cam in and see if it runs! If it does we'll go from there if it doesn't that means you got some other problem!
