Exhaust Cam breaks.
luigi711
Car: 89 240sx
HEy, I've been having trouble getting my exhaust cam to not break.I've broken three of them. I don't know what i'm doing wrong. they all broke in the same place. Can anyone help?
kpc_0721
Car: 1991 240sx hatchback
Are they breaking while your driving the car or while you are trying to pull them?
24DSXY1
Car: 1991 NISSAN 240SX
Maybe the head is warped on the exhaust cam side.
luigi711
Car: 89 240sx
I haven't drivin it yet. The one i had running then i had to take it back off and it broke. one broke when i was trying to get it to start and the other one i put it on and i tried to get the chain on the intake side and it broke when i took the sprocket off.
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
Looks like you're encountering a seizing condition on one or more cam journals which may be due to lack of oil.
LayNLow240
Car: 92 240 coupe
rogoman wrote:Looks like you're encountering a seizing condition on one or more cam journals which may be due to lack of oil.
Wtf? Did you even read? he said Quote »and the other one i put it on and i tried to get the chain on the intake side and it broke when i took the sprocket off.[/quote] It wouldn't need any lube if he's trying to get the chain on the sprocket.
luigi711
Car: 89 240sx
I know its getting oil. I had it running with the one cam before it broke and oil was on the valve cover when i took it off.
redlineracer
Car: 1991 nissan 240 sx coupe
i had the same problem when i broke my cam it bent 4 exhaust valves so it wont turn all the way over
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
LayNLow240 wrote:Wtf? Did you even read? he said It wouldn't need any lube if he's trying to get the chain on the sprocket.
Yes, I read his postings. Cams just don't break that easily.
You have to remember, we're sitting at a computer screen trying to figure out what may possibly be wrong; we're not there to see the problem; we don't know his expertise level.
He may possibly have two problems:- incorrectly removing the cam sprocket- one or more cam journal are seizing up for what ever reason
180fan
Car: 89 fastback
you puttin any lube on these cam journals and towers before they're going for a spin or you putting them in dry?
they breaking before the first cam tower or behind the sprocket, how are you trying to hold it steady when tightening the sprocket, you using the right bolt/sprocket on the cam, more details.
luigi711
Car: 89 240sx
No I wasn't putting any lube on it. a friend of mine told me that i should the other day. They are breaking before the first cam tower. I have a pair of channel locks to hold it while i tighten the sprocket bolt and they are the right sprocket and bolt.
(camera phone)
Scooby24
Car: 01 BMW 330CI
Are you following the proper bolt removal/assembly order? Are you putting assembly lube on the journals/bracets? Are you tightening down the cam prior to installing the sprocket?
