Cool. At what point would it start hindering me?240z4u wrote:At this point, its not hurting you.
Ah, ok. Thanks.240z4u wrote:To be totally honest, I am not sure. If/when you upgrade to a larger turbo maybe just weld in a 3" resonator. Keep in mind, it won't likely do as good of a job at toning down the exhaust though.
It's a venturi effect-the same principle of the carburetor and Nissan's SCV system. It's resistance that increases velocity also. You have to imagine air flow as if it were water. Imagine putting your thumb over a garden hose outlet, decreasing the diameter of pipe but still allowing flow.
Mine is. I have a syko turbo elbow.Genpac wrote:Is the RB25 turbo outlet really 3"? I know the RB20 is only 2.5" to the DP.
Still flow...yes, but creating back pressure at the same time most likely. A turbo car would probably take negative back pressure if it could, thats how much it doesn't like it.Neejay wrote:Ah, ok. Thanks.240z4u wrote:To be totally honest, I am not sure. If/when you upgrade to a larger turbo maybe just weld in a 3" resonator. Keep in mind, it won't likely do as good of a job at toning down the exhaust though.
Someone explained to be like this: http://www.youtube.com/watch?v=oUd4WxjoHKY
Understood, but I'm trying to gauge are we talking about 2-3hp, 10hp, 20hp? (obviously roughly)julio wrote:Still flow...yes, but creating back pressure at the same time most likely. A turbo car would probably take negative back pressure if it could, thats how much it doesn't like it.
