Perrenial Badass »
https://forums.nicoclub.com/perrenial-badass-u98460.html
Fri Jun 13, 2008 6:41 pm
On turbodiesels, I have seen exhausts with short expansions right off the downpipe that do create suction. This pulls the exhaust right out of the engine and provides a boost in power and torque.
Over a very small RPM area. This is often tuned to provide extra towing power where the truck needs it the most. But the suction that you need to think about is that behind the exhaust at the engine. The exhaust cannot physically move away from the turbo unless the air between the engine and the turbo moves. The "air pressure" in the pipe... or lack of it... will overcome any motivation to exit the pipe. Because there will be nothing to fill the space where the exhaust used to be.
That said, this suction has less effect as you get closer to the end of the pipe. At, say, the muffler, outside air can enter the exhaust system. Since the exhaust is hot and wants to expand and rise, it will exit and outside air can enter the pipe. But there is no air inlet at the exhaust side of the turbo. Unless, considering the age of our cars, we have rust holes in the piping. At which point, you'd be right, the exhaust will go right out that hole.
There is such a thing as too big of a pipe. But not because it causes you to lose power, but because it is inefficent for your size motor... well, exhaust flow... needs. Usually, a overly large exhaust for a car makes it peaky, whereas a correctly sized unit will make the most power in the midrange... although the peak power gain will most likely be less than the larger unit.
