fiznat »
https://forums.nicoclub.com/fiznat-u1372.html
Mon Jun 27, 2005 12:00 pm
Florida I think you are thinking of open wastegate dumps, not actual open downpipes. An open downpipe is just silly, I cant imagine that even for a track-only car. An open wastegate dump is loud as well (my wg is this way), but only when the wastegate is open (when you are at full boost). Usually at that point you're breaking a few other laws as well so whats one more, right? haha
As far as making your exhaust, ideally you should have the whole system at a constant diameter (like 3" from the turbo all the way back). You can find mufflers only at any size you want at a lot of places... I bet Greg would be willing to work something out with you for a B+M muffler-only if you wanted to weld that on the end of your piping. Keep the diamater uniform though, and dont get crazy with the complexity. Also you should think about cutting the pipe and welding in flanges for a test pipe/cat replacement in case you ever need to emissions test and need to swap a cat in there.
It shouldnt be too hard though, good luck doing it and get us some pics!
