exhaust and performance
qburkes
Car: q-45
Will a dual exhaust system cause me to loose back pressure- Will it make the Q run sluggish?
rsiwicki
Car: 95 Q45T
Uhhh...that would be a negative. Your pre-cats and secondary cats will ensure you keep plenty of pressure.
Now as for me...I have no CAT's and I am running custom headers with 2.5" mandrell bent x-pipe that is a very nice setup with 2 resonators and 1 magnaflow muffler at the rear. I don't have any HP loss from a totally free flowing system.
qburkes
Car: q-45
well i took off the resonators and replaced them with flow masters then i ran 2 pipes out of the back. I am planning to put a stillen single exhaust on the car to see if it helps out with the sluggishness.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Uhhhhh......you need to read the previous posts.
Very little restriction in stock dual exhaust sytem, so no signficant gain available by changing it.
Hope everything else on the car is OEM as new conditon and you are just playing.
jamesmost
Car: "95Qmodded, Benz wagon 4matic , 1986 MB 560sec
rsiwicki wrote:Uhhh...that would be a negative. Your pre-cats and secondary cats will ensure you keep plenty of pressure.
cut the resonators out
q man bk
i had myt precats gutted, 2 & 1/4 pipes with 2 free flow cts and 2 resonaters and a flow master 50 series dual in/out muffler waste of money if your car is noit super or turbo charged, stock motor you lose back pressure/power etc I went back to stock exhaust
CrimsonQ
Car: Purple People Eater
Modified by CrimsonQ at 5:15 PM 8/30/2005
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
CrimsonQ wrote:id could care less about power
Then modify at will!
I will be happy with full power, long sytem life, and a nice sound when run it to redline.
Cost to me: $0.0
Benefit to the car; more money for preventative maintenance.
Loud does not mean fast.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
If anything an exhaust system will reduce weight... Factory system IS restrictive (somewhat) and IS heavy... Main thing to change is the rear muffler... Sounds better, reduces weight, and does have some positive HP increase. If your staying N/A, then no reason to change anything before the rear muffler...
CrimsonQ
did i ever say it did?
Magnum PI
Car: (former owner of1994 Q45t)2005 Dodge Magnum R/T, 2008 350Z
elwesso, change to what brand and model for 94 Q? thanks Magnum PI
