Exhaust and intake pics all installed
07M45sGUY
Car: 2007 Infiniti M45s....Megan mid pipe and axle back RC2 intake. 18 percent tints all around and 4300k foglights. coilovers are next...
i just finished putting on my Megan mid pipe and axle back exhaust along with my R2C intake and im very happy with the products and they price was very reasonable as well. hope you all enjoy
The Bodyguard
Car: 08 Infiniiti M35 black loaded custom VIPDOUT
08 Infiniiti G35 S sold 92k miles
08 Infiniiti M45 S sold 78k miles
07 Infiniiti M35 traded 53k miles
95 Infiniiti J30 sold 155k miles
Location: Cypress, TX (Houston) o.g. from southern cali (North Hollywood)!!
Nice!! I didn't get the mid pipes yet, but will soon!! Other than that we're set up the same... Megan and R2C intake!! :dblthumb: after 3k RPM is when you'll really enjoy it!!
07M45sGUY
yeah after 3k its really nice i def love the exhaust note. ive gotten alot of compliments already. next mod will be coilovers and getting rims powdercoated
DeanM45
Car: 2006 Infiniti M45 Sport 1 or 2 mods
How's the overall performance increase? Noise level? R2C intake is going to be my next purchase as I pulled some vacuum readings on the stock system. Above 3500 and 1/2 throttle or so there is 1"-3" of vacuum (gets higher with more throttle angle/rpm). This is with a new Infiniti filter installed. Obviously there is some restriction there. I would imagine that the stock exhaust system is not terribly restrictive but then again I haven't taken any readings (pressure) yet (that's a bit more involved as there are no easy access points in the exhaust after the O2 sensor ports).
Maybe someone knows:
what size (cc) are our injectors (2006 M45S)?
what is the baseline fuel pressure?
Thanks!
06M4.5
Car: 2006 M45
07M45sGUY wrote:yeah after 3k its really nice i def love the exhaust note. ive gotten alot of compliments already. next mod will be coilovers and getting rims powdercoated
Your next mod should be Uprev tune
While the Megan Racing full exhaust will give you some power (est. 8hp) thru the full range the intake will make you lose power at the bottom end which is the range that you use the most (under 3500rpm).
The Uprev tune may be able to re-map so that both exhaust & intake work together at full range. The tune should be done on a dyno and not at home.
kermit the guy
Car: 2008 infinity M35 Sport
sound clip ?
CPJ LB
Car: 12 G37X Sedan- stealthy modded
14 Altima 2.5
08 Tahoe
06 M35 S (gone)
14 Versa 4dr (gone)
^ +1 ... interested to hear how the intake sounds w/the Megan... SOUNDCLIPS!! :)
