Sechsterlo »
https://forums.nicoclub.com/sechsterlo-u62697.html
Fri Oct 24, 2008 5:37 pm
I took it to the shop, and being able to get a look under the car, the guy looking with me found two issues. One, the hanger that is just behind the axle was loose, and really wasnt doing anything to hold the exhaust still. I mean we had a crazy amount of play where the hanger was connected to some metal that was flexing really bad. Solution: He welded a new hanger in place to keep the rear portion from moving around so much. The other issue was at the front. The header is actually rubbing up against something (possibly a heat shield of some sort?) in the front, and its causing vibrations when I first start the car and go down the road, but it isnt persistent, it tapers off. Im not sure if theres anything I can really do about it, the header isnt exactly flexible, and the exhaust is sitting where it should. I may have to take pictures for you to see what Im talking about there.
To answer your question, I was using all the rubber mounts. At this time I wonder if all of them were stock. Seems a previous owner had some, lets say, less than quality pipe fabrication installed. I had at certain times heard a bump under the car when it would cross train tracks for example, and that has since ceased. I figure it must have been a clearing issue in the back half somewhere.
