Exedy vs. ACT Clutch
mackdaddy240
Car: High performance with a clean look.
EXEDY!, I have had both ACT and Exedy. My ACT was stage two, engaged extremely harshly and the bearing started squeeling after a couple weeks of driving, I called ACT they said its normal because the heavy duty pressure applied more pressure so the bearing would make a little squeeling when the clutch is disengaged. I wasnt satisfied with that answer. I bought a EXEDY stage 1 I've had it for about 4 month of hard daily driving, difting, and dragging. Still holding out great, no noise, smooth engagement. And it was cheaper then the ACT clutch, now the act stage 1 might be about the same but from my experience I'm sticking with EXEDY
mhsz34
Car: 240 sx
What about RPS clutches? any other comments for them?
ILikeMy240sx
Car: SR Power
aleph1 wrote:I vote for RPS MAX Street. Amazing clutch.
I just bought this RPS Max Street and replaced my Fidanze alum flywheel surface.
I broke it in and its awesome. Pedal feel is great and is awesome for daily driving (very smooth engagement and no chatter) but holds 425 ft*lb of torque...
otterman
srdrps13 wrote:i have the exedy stage 2, its really rough for daily driving so get use to it.. other wise it holds really well. go with the exedy..
It took a little bit to get used to mine but its worth it.
g-man
Car: 1991 240SX
I have been thinking about changing my clutch as well, but I want the stage 2 clutch that is the closest to stock feel that I can find. Any comments on which one that would be ?
