Justin35ll »
https://forums.nicoclub.com/justin35ll-u118020.html
Tue Mar 10, 2009 4:41 pm
It makes the whining sound in reverse cause the gears are spur gears not helical, but if you're getting that sound in 1,2,3,4, or 5 first thing you should do is drain and refill the trans with new fluid.
If it still makes the sound it's possible the trans might need replacing or a rebuild.And also my ka had the same problem with the noise when the pedal was not depressed and then it would go away when I depressed it. Never fixed it cause I swapped the motor, but I figured it was the TOB, but it's weird cause you had that replaced so.It's weird cause my clutchmasters stage 3 clutch pedal is very soft. When I first bled the system I thought something was wrong I was expecting it to be a hard pedal, but I've bled it several times and adjusted the hieght and I guess it's just really soft. So that could just be the way the clutch is too.
