Exedy or SPEC clutch??
Justin35ll
Car: s13 coupe sr20det
Well since I just recieved some money I'm going to be putting it into my sr. Next thing I need is a clutch so.. debating on the exedy stage 2 or SPEC stage 3
Exedy st. 2 - 380$3 puck discholds up to 400hp
Spec st. 3 - 340$6 puck discholds up to 450 ft/lbs of torque
Not sure which one to go with. I know a lot of people around here like exedy. Anyone have experiences with either of these?
supreamS14
Car: 96 240sx S13-blacktop Sr20deT
I have a exedy stage 2, It's never slipped and I like it but I can't find a replacement clutch disk. I called exedy, got the part number, called all there supplier's and googled my ^$$ of with no luck. It sucks. I did find some replacement clutch disks in china but after shipping cost's it would probable cost the same as the hole clutch kit. Exedy customer service told me they have them in stock but I would need to get it from there supplier's. There supplier's told me they would order it for me and they would call me back !!!
1 suppliers told me that I should never replace just the clutch disk because the pressure plate will explode from not being replaced with the disk from too much heat ! I find that kind of hard to believe and think he just wanted to sell me a hole clutch kit. 1 & 1/2 year of daily driving @ about 250whp with about 18 drift days, 10 drag race test and tune's and 1 autocross I think I just about got my money's worth out of the clutch kit. It still has a couple month's left. I would like to be able to replace the clutch disk at least 1 time rather than a hole kit every 2 year's.
I'm really starting to wonder if it would be ok to put in a act 6 puck and have the pressure plate and flywheel resurfaced. The pressure plate feels as strong as the day I got it. Anyone know if that would be ok?
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
You should be replacing the pressure plate when you replace the disk.
As far as clutch stuff goes, I have had very good experiences dealing with spec. Friendly people and very good about taking care of problems if they come up. Hell I even helped them prototype a Maxima flywheel!
S13FASTBACKSR
Car: '92 Fastback SR powered
exedy is far superior to spec
Justin35ll
Yeah, that sucks about not being able to find the replacement disc, but if you got 2 years out of it and used it to it's potential than it seems worth it.And yeah I would probably replace the pressure plate as well if I was changing the disc out
Any more opinions on which would be a better choice?
J240sx
Car: 89 240sx
Im pretty sure either one would be fine. I never had a problem with my spec stage II.
Koshin
Car: JP'd out Y32 Nissan Gloria GTU
750 hp '87 Buick Grand National
'63 Chevy Impala SS 327/4 speed
S13FASTBACKSR wrote:exedy is far superior to spec
+1
the converted
Car: '99 BMW M3 6.0
'20 Toyota Tacoma
91SilviaKs wrote:
+1
Proof? I know you can get just a disk from them if you want to.
Koshin
^^^I just speak from personal experience...Ive had buddys that did not like their SPEC clutches, and actually switched to EXEDY..Ive never had a spec becasue I figured Id save myself the trouble of buying two clutches...No proof, just experience
Justin35ll
Yeah, anyone know about clutchmasters? my friend can get me a hookup through them so I can get a stage 3 for about the same price as exedy stage 2Anyone ever use one?
Modified by Justin35ll at 4:01 PM 12/1/2008
Jables
Car: 1995 RB26DET S14, 1991 RB25DET S13, 1992 S13 LS1 Coupe
How about you just give me a call and let me set you up with what you need. I am more then happy to help in any situation.
The Converted- Thanks again for you help dude. You da MAN!!!
Thanks,Justin
jr_ss
Car: 95' S14
Personally, I think RPS clutches are better than Exedy or Spec and I speak from experience. They are a bit more expensive, but hold more power. I did like my Stg II Spec in my other car though.
Oh and never buy a clutch for it's HP rating, it should be the TRQ rating that you want to go by. For instance, something rated at 400hp could mean that it will only hold 300ftlbs of trq or less... Always, purchase a clutch based on it's trq rating...
Justin35ll
Yeah, I found it weird that they rated it by hp and not torque. Oh well this thread is done I purchased the clutchmasters stage 3
