Postby
motoxris »
https://forums.nicoclub.com/motoxris-u63974.htmlMon Mar 08, 2010 9:14 pm
Have any of you used the exedy clutch master cylinder or slave cylinder? these parts are at thmotoring for a good price and exedy makes good clutches.12 bucks for the master cylinder6 bucks for the slave cylinderIs there any reason I shouldn't go for this? Thanks everyone?
Postby
fiznowler »
https://forums.nicoclub.com/fiznowler-u64709.htmlTue Mar 09, 2010 5:44 am
i bought both of those to try when i swap mine. I figure if it doesn't work i will just run up to the parts store. I got it in mine looked to be pretty decent quality. Haven't used it yet but seems to be ok.
Postby
motoxris »
https://forums.nicoclub.com/motoxris-u63974.htmlTue Mar 09, 2010 6:13 am
Hmmm. Well there pretty simple parts as long there machined correctly and use correct measurements/seals,etc. Should be ok. I don't know why exedy wouldn't charge more. Hopefully these parts are reliable.
Postby
fiznowler »
https://forums.nicoclub.com/fiznowler-u64709.htmlTue Mar 09, 2010 7:16 am
I hooked the clutch line up to master and slave and pumped it with just air sealed air tight and actuated the slave like it is supposed to i really don't see why it wouldn't work.
