exclamation point ! light on dash?
swolpoppa
Car: 2004 inifiniti G35 coupe
what does that light mean if it appears on dash on my 2004 G35 coupe?
Kendahl
Car: 2008 G37S, Blue Slate, Premium, Navigation
That's the warning that shows up when the car thinks you have a tire with low pressure. (Read about the tire pressure monitoring system, TPMS, in your manual.) As soon as possible, measure the pressure in all four tires. You may have a leak. If so, you want to get it repaired promptly. Running a tire when it is flat is sure to ruin it.
TPMS can give a false alarm. (Infiniti is not the only brand with this problem.) If the tire pressures are correct, talk to your dealer's service department.
joe603
Car: 2014 Durango R/T
Yup, one of your tires has less than 30PSI. Fill 'em all to 35PSI and the light will eventually go away.
telcoman
Kendahl wrote:That's the warning that shows up when the car thinks you have a tire with low pressure. (Read about the tire pressure monitoring system, TPMS, in your manual.) As soon as possible, measure the pressure in all four tires. You may have a leak. If so, you want to get it repaired promptly. Running a tire when it is flat is sure to ruin it.
All four tires should have at least 35 PSI + a few extra lbs measured when cold. Tires lose pressure as the temperature drops in winter. Obtain a good quality tire pressure gauge & don't relay on guages at the gas stations.
Telcoman
