LDMF »
https://forums.nicoclub.com/ldmf-u250891.html
Wed Apr 22, 2015 7:02 am
Sooooo.....
I found a 1993 300zx TT in saphire blue.
5 speed,
t tops,
1 owner with maintaince records, Timing belt, water pump...has been done
100k.
And I stole it for $4k.
It has been driven sparenly for the past 5 years. The lady told me she would just take it around the neighborhood until it would get warm and then bring it back and put in the heated garage. Very dusty but amazing shape. Interior excellent. everything seems to work. On a battery tender. It started right up and idled smoothly. It did have a tick at the top middle of the engine. Valve tick, intake leak, exhaust leak??? Boost sat at -12 or so, goosed the throtle and it jumped up to 0 or close to. The idle did rise when I depressed the clutch, weird.
Took the car out for a ride, clutch seem good, reverse worked well, ran it through 1st 2nd and hit third at low revs. No brakes at all, none zero zip. Brought her back and looked at the brake rewsivior and it was dry. looked at the calipers and none showed obvious leakage. All the the inside of the wheel were dry. No marks under the car. The Master cylinder did have a bunch of corrosion, so that is my guess on the noo brakes issue. Plenty of brake pad visible.
Question time:
Obviously I need a master cylinder.
Need to change out all the fluids (Cluctch, Diff, Trans, Motor oil, Rad was bright green so maybe)
Anything to check for the tick?
What else should I be looking for?
Thanks you all in advance,
LDMF
