yellow_jacket »
https://forums.nicoclub.com/yellow-jacket-u4236.html
Fri Apr 25, 2003 9:19 pm
If it only happens from 1-2 then the transmission needs to be rebuilt.
You can try changing the fluid and adding some trans-x or something like it. Sometimes it will work and sometimes it won't. A lot of it depends on the fluid condition. If the fluid is burned, changing the fluid will usually smooth out the transmission.
