Excessive play in the driveshaft?
imotion s14
Car: 1997 240SX
Finally got around to installing my DS. Noticed I have about 1" play in the driveshaft. I'm sure I measured it correctly, I measured roughly 45 3/4" from the output shaft to the flange. It seems to be pretty excessive.
setup: RB25, S14, R33 VLSD, Syko mounts.
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
did you get a one piece d/s or is it a sky d/s? mabey bad carrier bearing? you said it moved about a inch? what around in the tunnel of the car or in n out of the transmission to the diff? aftermarket or nissan?
imotion s14
Car: 1997 240SX
bah forgot to mention that.. custom 1 piece and I mean back and forth play.. or as you said in and out of the output shaft. 1" seems excessive but I never really measured the play in the stock DS when I had the KA.
leesredgt
Car: 1992 Toyota MR2 N/A
1991 Toyota MR2 Turbo
How can it slide back and forth if you have it bolted to one end?When i put my McKinney drive shaft in i had to put it in then pull it a lil. back for it to work.I wouldnt worry about it to much.
imotion s14
Car: 1997 240SX
leesredgt wrote:How can it slide back and forth if you have it bolted to one end?When i put my McKinney drive shaft in i had to put it in then pull it a lil. back for it to work.I wouldnt worry about it to much.
I never bolted it to diff input flange, just slid the yoke all the way into the transmission output shaft. There is a gap with it slid in all the way between the diff and DS. I know there should be some play but 1" seems pretty excessive to me.
leesredgt
I forgot how much i had to pull mine back.how much of the shaft is actually in the transmission?
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
The rule of thumb is to measure from the output shaft in the transmission to the input flange on the diff and subtract 1/4". One inch seems like a lot of play to me, but I don't know what the negative effects will be, if any. I don't think you'll be putting down enough power to actually break the shaft, but it may introduce some vibration into the drive train.
SullivanRacing06
if he still had a stock 2 piece then yes it would move around in the tunnel b/c of the stock carrier bearing
imotion s14
Car: 1997 240SX
leesredgt wrote:I forgot how much i had to pull mine back.how much of the shaft is actually in the transmission?
roughly 3-1/4" inches, the yoke is 4-1/4"
Darius wrote:The rule of thumb is to measure from the output shaft in the transmission to the input flange on the diff and subtract 1/4". One inch seems like a lot of play to me, but I don't know what the negative effects will be, if any. I don't think you'll be putting down enough power to actually break the shaft, but it may introduce some vibration into the drive train.
That's what I'm thinking, just looking for a consensus.
