keepingthe240 »
https://forums.nicoclub.com/keepingthe240-u3686.html
Sun Aug 15, 2004 7:03 pm
This morning i took the brake pads off and put new ones on. I tried to push the caliper in with a c clamp, with no luck. Strange enough, the rotor have yet to seat on that side The rotor could be taken off with the slightest pull. Bad thing is, the store can't get me a new caliper until the 23rd and i work 15 miles away. How can bleeding you brakes wrong cause the pads to go bad quicker? It's not the parking brake, the other side isn't worn down. I was figuring the brake fluid caused the pads to become soft and worn at a faster rate.
