SteveTheTech wrote:
I agree whole heartedly but the amount of people out there who know how to correctly perform these tests and give an honest answer as to the results are continuely decreasing. The new breed of guys are not really outside the box thinkers. Oil consumption is one of those things that you think would be obvious but they can be pretty tricky.
If this were mine, I would start by pulling the plenum before doing much else, if nothing else it makes getting to the plugs easier and you would able to clean and thoroughly assess the pcv system. Pull the plugs, loosing that much oil has to leave a sign somewhere. A compression test would be the best/cheapest test to diy if that is the chosen route. But to pay for these tests is going to be pricey.
I have one. It was like $100. But you are right that modern techs are a somewhat less into this type of detail. Which is why I do my own work when I can. For anything else not specific to Nissan, I go to an independent shop.
As for removing the plenum, I didn't even need to remove the cover over the plenum to get to the plugs on the Titan. Can't imagine it would be that much better for access to the plug holes.
I agree the sompression test would be cheaper. I think the only thing you really lose out on is measuring leakdown while moving the piston through its motion. For detecting where the air ends up, most compression testers have the same quick release that a leak down tester has so you can plug it straight onto the end of a compressor hose and regulate the pressure through the compressor (perhaps not as easy for shop air though).
