I was topping off the refrigerant in my a/c today (first time since I bought it in 2001
So after a test drive I pulled back into the driveway, and noticed a high pitched squeal or whine coming from near the right rear wheel area. It sounds a lot like some electric leaf blowers, or almost electronic like an alarm of some sort. Anyhow, I opened the gas cap and got a huge rush of fuel vapor. It seemed like a lot more than normal, although I don't normally take the gas cap off with the car running. The noise stopped instantly. I also noticed a new odd sloshing noise in the gas tank after turning the car off.
I've never heard of this on any Q before, but at 26 years old, weird stuff is bound to happen. My theory is that the fuel vapor check valve is stuck closed, allowing the vapor pressure to build up in the tank. I'm guessing the squeal is a vapor leak from the weakest point in the vapor line. I'm not sure that I've ever seen the part, but it looks like there is one somewhere underneath the car.
I'll try to check it out soon and post the results here. If anyone has experienced this before I'd love to know about it too. I did a bit of searching for this on Nissans in general, and didn't see much.
