oldandslow »
https://forums.nicoclub.com/oldandslow-u91390.html
Thu Apr 10, 2008 12:35 pm
Im guessing that You have an intake vacuum leak.Removing the oil cap will make the sound go away because it creates a bigger vacuum leak.Removing the oil cap from most modern cars will create a vacuum leak that will make the car run rough,and then the computer will adjust for it.This is because most modern cars have a closed vent recirc system.(not open to atmosphere)The reason for the closed system ,is to have a way to vent the system ,without inducing unmetered air into the intake charge.If Your car doesnt run rough when You remove the oil cap,that would be a good indication that You have a vacuum leak somewhere other than the leak You created by removing the cap.Also,do these cars have a crancase vent valve? This valve is in the crancase vent system similar to a pcv valve.This valve is used where there is a closed system ,unlike the older pcv valves that were an open system.This valve is usually under the intake manifold,or on the back of the intk man.Jeff F
