Red coupe »
https://forums.nicoclub.com/red-coupe-u19771.html
Fri Sep 02, 2005 10:10 pm
rear doesn't have caster??? lwhat kinda excessive camber? negative? positive?Negative camber the top of the tire points inward, like on lowered cars that haven't been fixed... positive the tire leans outwards at the top..
caster is the forward/rearward tilt of the shock. positive caster places the wheel ahead of the upper pivot, like a bike, negative places the wheel reward, like the wheels of a shopping cart.
Do you mean toe? toe is whether the tires are parallel or pointing towards each other.Toed in the front of the tire points inwards, toed out is the opposite...
Look under the car for damaged/bent parts...have you hit anything? messed with any of the bolts on the arms? installed new suspension components???
