I brought my own oil to the service. An unopened, 5lt Castrol Synthetic 5W-30 oil. All they have to do is lift the car, drain the old oil, change the filter and pour 4.6 lt of oil. That was so simple...
This morning I checked the level of my oil. It was well above maximum. I mean it was at least 1 inch above mark "H". I couldn't believe my eyes, so I checked at least 10 times....but no, that idiot filed the engine with the whole 5 litres of oil! I can understand + / - 100 ml, but it was more than that.
So I could go back to the dealer and complain. In that case, what they will do is to lift the car, unscrew the drain plug little bit and let 300-400 ml of oil leave the engine. The problem is I don't trust them. They can easily strip the bolt on the drain pan or God know what else when they are performing something unusual. On the other hand, since the mechanic will be extremely upset, he may "accidently" damage the car? Who knows...Next time I will but a huge post-it on the oil bottle and say "Please fill the engine with 4.6 lt only".
My solution is to suck 300 - 400 ml of oil from the dip stick hole with a tube and syringe.
My wife thinks I am crazy, but I know it is not good to overfill the engine.
Do you think I am crazy?
Do you think I should ignore 400 ml (0.42 US Quarts) of excess oil, or sucking is a good idea?
