97240SXSE wrote:Note I need help with my Caster not Camber. To my knowledge, Hawaii is the only state which requires a reconstruction permit when modifying any vehicle which is driven on public roads. To acquire this permit, alignment papers must be submitted and must be within oem spec.
whoops i misread. damaged tension rod, damaged flca, damaged shock tower could all mess up caster. if you are trying to get it into spec just to get an inspection sticker or whatever, and had camber plates, you could rotate the upper mount so that the camber plates affect caster as well as camber.
