umm, most n/a exhauts are 60-65 mm Most turbo exhaust are 80mm+. so that looks more like 15-20mm larger. Not trying to be a a*s. If you are going turbo in the future, get the bigger exhaust. If you have a 5spd you will barely notice the difference on n/a power loss. The hks hiper is available in several versions 65mm, 80mm and the 25th anv model is all stainless. If you have the extra money, go all stainless. Hope that helps.
Also
http://www.nopi.com and
http://www.optauto.com both have the hipers in stock. I have done business with both companies and have not had any problems.
