Exaust manifolds interchangable?
namwons_240
Car: 97' 200sx ser
I have an s13 sr and my friend has an s14 sr and was going to give me his tubilar bottom mount since hes switching to top mount. Was wondering if the manifolds line up and bolt correctly even tho one is high port and one is low port. Searched this and barely anything comes up for exaust manifolds.
Hijacker
Car: '92 240sx Convertible
'94 F-150
as far as i know, they're interchangable. but since this is a cost free situation for you, go ahead and pull your old manifold off and verify that they are.
biglipzit
Car: sr20det S13 RHD 200SX
would there be an advantage of using an S14 exhaust manifold over the S13 manifold?
Slo S14
Car: 1995 240sx Base
^ Unless it has different flow characteristics i wouldn't think so. Swaping out JUST the manifolds and not the turbos would seem pretty pointless unless something happened to your stocker. The initial post was about a tubular s14 manifold.
Ni2s4s0aSnX
Car: Nissan 240sx 2.4L 12Valve
I believe they are.
ca18det_boy
they are the same...it will all fit together. There isn't any advantage over an S14 mani or an S13 mani.
