aither »
https://forums.nicoclub.com/aither-u7317.html
Fri Jan 23, 2004 12:12 pm
give it a day, and the PG crew will school this kid with something like, "You should run 17x9 +0 up front, and 18x13 -20 in the rear. Run a 215/40/17 size for the fronts and a 205/30/18 for the rears. You'll probably need to roll your fender, and rivet on a set of over fenders for that ultra flushness. Also, you may need to dial in a bit of negative camber, but that set up will be the hotness!!!
