Exar-Kun wrote:1550 for a gram light pro in a correct offset is a good price, for all four.-chetyou can run a 255-40-17, on a 17x8.5 or 17x9 if you want, and it will fit fine, but you may want to check into fender flares if you dont get the offset just right.
Hmmm. Thanks. The 17x9 pro's only come with a +35 offset for the 4x114.3 pattern. Will that offset cause a problem with the 255-40-17s? Also, I don't think the 17x8 will fit in the front because it has the same +35 offset. I guess I'll go with a 17x7 in the front and 17x9 in the rear. By the way, I have a 91 240.
Could I roll the fenders? I'm not a big fan of fender flares (unless they are molded).
Thanks, Johann
