EXACTLY which Z32 Calipers
trpower7
Ok, I know all this information is readily available, and I believe I have it all straight. However, let me appeal to all of you and make sure I have this correct. I plan to upgrade my base model, 4-lug S13 to five lugs, and Z32 TT brakes and wheels all around. My list of parts is as follows:
1) 2 Z32 Rear hubs (bolt on to S13 spindles)2) 2 S14 5-lug front hubs AND spindles3) 2 Z32 TT Front Brake Rotors (five lug)4) 2 Z32 TT Rear Brake Rotors (five lug)5) Front and rear Z32 Brake pads6) SS lines for all corners7) 4 Z32 TT Wheels and Tires8) Rear e-brake fitting for Z32 calipers9) Line adapter for rear calipers
I think that is all I need, but I need someone who is knowledgeable about this sort of thing to run over all the particulars if I've missed anything. Thank you very much!
Nismo1182
Car: Z06
i dont think any would with out some spacers.
Dragon240
To the best of my knowledge none will work with stock wheels.. Everything I've seen suggested 17" wheels and even some of those have clearance issues I think..
Exar-Kun
Car: 2005 350Z
no 300zx caliper will clear the steel wheels. now settle down. GO buy some Seven spoke alloys from the s13 SE models, and then you can use the 26mm calipers(supposively)-chet
Dragon240
Or.. buy 5-lug conversion and 300zx wheels ;)
trpower7
bump
Exar-Kun
Car: 2005 350Z
http://www.sportcompactcarweb....lvia/
its got everything listed there.-chet
also, check http://www.PDM-Racing.com
don has both the parts and knowledge to do what your looking for.
trpower7
thanks
Dragon240
You have to have conversion lines for the front.. didn't see that listed, just "SS Lines"
